Cases built for Dual Systems (Full ATX)
Well Protocase finally responded with a rough quote, and at that price, is not close to reasonable. So I guess it is back to square one.
That's a shame, but I did warn you they are not cheap!
The way I see it, you have 4 options:
1) Find a UK/Cheaper alternative to Protocase
2) Take a case from Caselabs and modify it somehow
3) Change the format of one of your systems so that you have an EATX/ATX + ITX system
Or a 4th would be to just run to separate systems in parallel.
Oh I expected not cheap. But they were quoting over £2100 :P
I'll figure it out. Will see other alternatives, at-least I have that option free if I can't find a better deal.
