Depends on what you call loud...mine is very quiet compared my old air cooled systems. The fact that it has an in built fan controller is very useful as well. I normally set it to level 5 and that is fine in all but the hottest weather...in the winter you can turn the central heating off and run the fans on setting 1 and have a nice warm room
The loudest thing in the PC3-725BK cases are those stock fans that come with the V1000 itself. Get some replacements and it'll be very quiet.
If there main custom is the same as OcUK's and within EU then yes they are a competitor, the shop stocks fans for one, so do OcUK, stocks fan controllers, so does OcUK.
You can mention Dell monitors, but linking to a Dell page showing a full system is not on, you can mention Koolance as a manufacturer but linking to a shop is not on.
If you have issue with that then take it to email as I offered, I will hand out suspensions if anyone else questions the rules on the boards. You have had your warning.
It's a shame that's the one bit of my new system I can't get from here. I'll still get everything else from here of course
The PC4-1025BK '1KW' Lian Li V1000 is the one I've been leaning towards, apparently the revision 2 version has adjustable pump speed which would hopefully allow me to make it as quiet as a PC3-725BK Lian Li V1000 but still with better cooling due to the 3-fan rad.
Yewen you've clearly done your homework on the Koolance systems; if money's not too much of a concern which would you recommend?
Firstly I have to say I have not used any of the current range, so I am speaking now for what I would buy from them, not from experience so it may be wrong!
ERM-3K4U5 = $1800, just because it looks a monster, but on planet earth I will be looking at getting this, or its successor depending on when funds are permitting:
PC4-1025SL = $600
I think that one is the silver version of your choice, seems to fit into the high end but not silly money catagory quite sweetly, looks the buisness aswell having owned two v1000s already.
Cheers Yewen, I've a feeling I may go for that one. Although I prefer the look of the V1100 case, and I haven't seen anywhere that stocks the 1024 (which uses that case), so I may end up going with the PC3-724BK Lian Li V1100. Or I may just ask one of the Koolance stockists if they can get a 1024 in for me.
Btw is there any chance you guys might stock them at some point? The only thing you currently have in that line is the W/C TT Tai Chi case, which from the sound of it is noisy and doesn't cool at all well. I know you couldn't have them in in time for me, I'm pretty imminent, but I reckon it'd make a good addition to your range
In fact I've just added a post about this in the Product Suggestions forum, 'bout time someone used it
Edit: Just noticed we can only see our own posts on that board, which is why it looks unused.
