Quick question. I took out £20 from the machine, it gave me £30.
My account says £20 was taken out. Error in my favour or will it be noticed?
Why are you back here posting on the internet?
Go back and clean the machine out!![]()
There used to be a trick you could do with those cash machines in shops (the ones that charge you £2.50 to take your money out) whereby you could get into the management screen (using a default password which was rarely changed) then swap around the £10 and £20 holders in the system. Then you put your card in take out say £100 and you'd get £200 but only a hundred would be logged against your account. You then logged back into the management screen and swapped them back again.
Pretty sure they've stopped it now though.
