I've been wondering about this. 5e is looking the best option for a normal house at speeds up to 10Gb. I presume it's not too difficult to install?
5e is slightly easier to work with and more forgiving of bend radius. In terms of ease, it’s not bad, but it depends on if the property is empty or furnished and what route you want to take and how adamant you are that the cable won’t be seen. Exterior runs coming out of air bricks and running behind guttering are normally quite unobtrusive and minimally invasive for exterior, interior wise I normally find a route to the lift and then bring it down. My own property is 3 floors, I hijacked the old boiler flue and put access hatches in each floor, I was briefly considering a run parallel to the soil stack, but an over enthusiastic plasterer replaced a ceiling quicker than anticipated. In other scenario’s I have run behind skirting or under floor, occasionally using flat cable next to gripper rods for cosmetic reasons. Whatever you need to do, it’s usually not as difficult as you think it will be. You get bonus points for rope and conduit though
