many shops and one large networking and cable supplier too. shady i guess but its rated 2000mhz so cant say anything without testing it a proving it wrong.
Deleted.
2000MHz - like 2GHz? What does that refer to exactly? s an antenna that would pick up the low-end of most people's front door bells if it was long enough. Or do you mean 2000Mbps? In which case most CAT5e can do that.
FWIW that clearly is twisted pair.
Kenable wouldn't be on my list of quality suppliers. Show me a flat cable from a manufacturer like Excel and I'll take it seriously.
BTW what's the use case for a flat Cat8 cable? I doubt anyone who's buying those cables it sticking 40GbE through it.
thats all i saw in the pic here have a look:
Why's that? I've used Kenable solid core cat6 outdoor cable with no issues as a good compromise between fricking thick hard to use/install cable and very flexible inferior CCA cable. I've never had it not deliver gigabit even over long runs with harsh right angle twists. It terminates fine and the internal twisted pair colourings do not fade. I don't have any 10gb equipment to test with an likely won't do for years as I don't have a usage case for anything above giga.
I dislike using anything more rigid or thicker to be honest as it's harder to clip to walls and starts to look unsightly requiring bigger cable clips. Becomes harder to go round wall corners without either kinking the cable or having a wide hang with an air gap. But yeah...Kenable has been fine for me. Ask me again after 10 summers if it still works. I bet it will.![]()
some people say you cant do 90 degree bends on these cables since its like a railway track and if the packets hit a corner at gigabit speeds they can "derail" as such . lol
Is that why? didn't know that. Thanks for the education![]()
Dunno avalon mentioned it was.Is it not true then?
