Got a few friends houses to network including cctv installation and I started one of the houses using blackbox kit.
I am having trouble terminating the RJ45 plugs onto the cat6 cable for cctv. There is always a core or two that doesn't crimp correctly when I test them.
I don't know if its the crimp tool as I didn't seem to have as big of a problem before with a previous installation but I did use different branded cable/plugs etc. Is there a chance this blackbox stuff is more suitable for their own blackbox crimper?
I've recrimped the plug a few times to see if it helps and some times it helps.
My crimper was a cheapo at £15 so maybe I might be better off investing in a decent crimper? Any suggestions?
