Hi
Having to move the router in my house. The exsiting location had wired connections to 3 other rooms that were installed years ago and are now surrounded by built in wardrobes etc. All works fine atm. When I move the router I can reroute all the cables so that i 'should' still have a wired connection to each room. One cable is going to be about a metre short (of course it is). Not a networking expert, but I've seen that you can buy male to female connectors as a way of extending the cable. Are they a way of getting around this? Running a new cable isn't really an option. The house has been extended a couple of times and the plugs aren't on the same circuits (or so I've been told), which makes the mains network adaptors ineffective. I could move the router to another location, but it would be a real ballache. Am I going to lose a lot of performance with this fix?
I suppose the moral is when you're installing cables think ahead to how much you might need in the future and then double it.
