Thanks for all of your posts very helpful thread indeed!
Decided to get the amalgamating tape that was sugested by edGfaCTor and go from their and ill try and run it behind pipes that are traling along the walls of the house for some defence.
cat5 should be fine outside if you want to protect it from water then buy some amalgamating tape it's normally used to protect connectors that go to sky dish but can work to cover the whole cable an IT Tec I used to work with always used it for outside cables and never had any problems.
