- 25 Feb 2025
- England
Premade or reel?thanks so this cable is called 'Time data cables' it says UTP, 4 pairs of 24 AWG and solid copper connector
Is that a good cable?
reelPremade or reel?
Solid copper, if it has the rubbery separator in the middle, it's probably closer to CAT6, if not it sounds like good quality 5e.reel
iirc 305 metres
Yea good pointSolid copper, if it has the rubbery separator in the middle, it's probably closer to CAT6, if not it sounds like good quality 5e.
Look for CCS on the cable, that's copper coated steel, cheaper stuff but it's still good enough for home use.
If you've got a load of RJ45s and the tools, give making one a go and see how it goes before running it outside. It hits 1Gbps or better (if you have the hardware), it'll probably do just fine unless you're a datacenter or enterprise consumer.
If you have multi-gig broadband, or shift files between PCs/homelab kit, yeah. If not, no. Pays to be prepared though, your PC is ready, just upgrade as you go before faster internet is available in your area.Right so it will prob be okay
Next question… is 2.5gb worth it? Lol
My pc lan port is 2.5 but the switch I got and my router iirc is 1gb
