http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
Release notes
Will report back when had some time to play
Release notes
Are theese older than the 8.95.5 drivers I'm using now?
Are yours 12.4 beta? If so then yes.
One thing I don't understand, the drivers are newer than the caps.
Does that mean that not applying the caps would actually mean the drivers would be using profiles which are more up to date?
Surely the drivers contain all the cap until the date they where released, applying old caps would role back the profiles even further....
This is why I hate this idea of caps...
Hmm, Thought I was already running 12.4
<Feature name="CoreClockTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A">
<Property name="Want_0" value="15700" />
<Property name="Want_1" value="60000" />
<Property name="Want_2" value="85000" />
</Feature>
<Feature name="MemoryClockTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A">
<Property name="Want_0" value="30000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="120000" />
</Feature>
<Feature name="CoreVoltageTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A">
<Property name="Want_0" value="950" />
<Property name="Want_1" value="1063" />
<Property name="Want_2" value="1163" />
snip
Am I right in saying it feels like AMD can't get anything right?
Like what is this going on with my idle clocks on the second card... first card on GPU-z.
And when I try to change the values of the idle clocks, it doesn't take effect. Like it's ignoring them completely. As I'm only running one screen.
Code:<Feature name="CoreClockTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A"> <Property name="Want_0" value="15700" /> <Property name="Want_1" value="60000" /> <Property name="Want_2" value="85000" /> </Feature> <Feature name="MemoryClockTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A"> <Property name="Want_0" value="30000" /> <Property name="Want_1" value="90000" /> <Property name="Want_2" value="120000" /> </Feature> <Feature name="CoreVoltageTarget_PCI_VEN_1002&DEV_6898&SUBSYS_22891787&REV_00_4&384A862&0&0058A"> <Property name="Want_0" value="950" /> <Property name="Want_1" value="1063" /> <Property name="Want_2" value="1163" />
It's causing heat for no reason. The card normally idles 27 - 29c.
