Catalyst Problems
1 Jan 2004
Walsall (UK)
Ok i need help, i have the system in my signature and everythink seemed ok, but when i install the drivers for my graphics card (ATI 6.5) im have wierd probs, like if i right click on desktop when doing things like copying from one folder to another etc for some reason the catalyst control panel drivers install again, and even if i goto edit and copy and paste that way it still happens and i dont have a clue why, and was wondering has anyone else had this seem problem or is it just me!, so im hoping someone can help ive tried uninstalling all ati software and trying again but still get the same problem, and im not sure if its the nvidea mobo drivers conflicting with the ati graph card or what but i just dont have a clue how to cure it so im hoping (fingers crossed) someone on the forums can help me as its annoying when i cant get the full software working as at min ive only installed the graph drivers and not the catalyst control panel which sucks, anyway hope to hear from you soon thanks. :confused: :rolleyes: :eek: :(
Never heard of that one before, so when you open 2x folders and try dragging the contents from one to the other it just installs the drivers again instead, and doesn't do the copying, thats well weird :confused:
You don't need the CCC as you can download ATi Tray tools from Guru3D so you can do all your AA/AF settings etc... a lot of ppl just do that as they don't like the CCC, and if the problem doesn't happen when the CCC is not installed, then id just do that till you find a fix. :)
1st, sig is to big, read the FAQ.
2ndly, uninstall the ATi drivers, using driver cleaner pro in Safe mode
3rd, Download Omega drivers, they contain ATi Tray Tools and they work better than the normal ATi Cats.
Conc
I think its only 4x lines of text allowed in a Sig, he meant safe mode of windows when you press F8 on start-up, yes those are the latest ones based on the Official Cat 6.5's. :)
