10 meters is different although next door to the CB band... Breakers on 11 meters work on verticals, 100watts where as 10 meters all kinds of antennas are used like horizontal wire antennas, and low power levels as well as high plus hams are also listening out for all signals not just the strong signals like they do on CB where there squelch is turned up and only care about the strongest signals. I have a couple of old CB radios converted to 10 meters that I'm dying to try out sometime when the next skip comes in.I worked PY a couple of days ago on a literal bit of wire I dangled out the window on 10m with 20W. Yes, I've got a decent SteppIR up but this was an experiment to see how well the bands are working at the (almost) peak of the cycle.
Also people are using much better radios when it comes to 10 meters, some of these HF sets of today have impressive built in noise reduction technology and the receivers are generally better, they would be miles better at picking up weaker signals and would appear as stronger than on an average CB radio. There are a lot of factors to play which separates CB from 10 meters.
