CCC problem with overdrive
11 Feb 2012
Up north.
So i built my new rig thats in my sig, i say new, but it was just the psu, mobo, cooler and case that were new. But im up an running and its totally fine.
The 1 problem I have is when i click on performance, then overdrive, click the accept on the warning they offer, and overdrive just vanishes. I shut CCC down, run it again and then its back, but same thing happens each time I try to get into it.
I re installed CCC to see if that works, and no dice.
Any ideas?
Open task manager and see if fuel is running.
If not go into C:\AMD\Support\12-4_vista_win7_64_dd_ccc\Packages\Apps\CCC2 and find the fuel draws and run the installs and see if that works.
I had this problem with 12.4 drivers for my 7970.Theres no trace of it running at all after you click accept ,although a re3boot brought the option back.I ended up uninstalling CCC anyways because it wasnt playing well with Afterburner
Hmm, 12.4 was really good for my little 6950 in bf3, not sure i want to roll back. Il just get After burner and give it some big licks in there instead.
