CCC problems
22 Dec 2012
Hi guys,
I don't know if I have put this in the right section, but any help would be appreciated.
I just used AMD CCC to overclock my cpu using CPU overdrive out of curiosity. Now, every time my PC starts, all looks okay, but as soon as CCC starts up, the display goes to windows basic.
Any suggestions on what to do?
Thanks,
Chris
First of all what version of ccc are you running?
My first step would be to update it if need be.
My second step would be to check your visual setting in windows, just press start and search AERO
