- 24 Feb 2004
- Leeds/Cyprus
I want to create a CD which will have 3 audio tracks and one video track (VCD or SVCD). Is this even possible? The burning software I use is Nero 6.6 - can it do it, and what option do I select?
The video file is under 20' long so I'm sure there'll be room both for it and the 3 audio tracks on it (right?). Will DVD to SVCD be a massive drop in quality? I'll be ripping it off a home-made DVD myself using one of the DVD to (S)VCD software reccomended in the freeware sticky above - although if anyone has a suggestion as per which of the lot is the fastest and easiest to use, or if there's a better one not mentioned in the sticky, please tell me as I don't have time to download and try them all out until I figure out which I prefer!
Svcds only support 2 audio tracks not 3 afaik, and the max resolution is 480x576 with a bitrate of 2.6Mb/s.
