Just reinstalled my rig yesterday with Windows XP Pro SP2, all runs fine, until i start to access the CD/DVDRW drive, the system slows right down and installs take ages. I have moved the drive to its own channel (IDE1), checked all cables. This seems like a very odd problem, as when the CD Drive is not accessed the system is fine, and the drive was working fine before the reinstall
Spec
AMD Athlon (OC to 2.2ghz)
1gb 2700 Ram
Abit NF7-S Mobo
160gb Sata Drive
Geforce 5800 (Softmodded to Ultra speeds)
External Buffalo USB Hard Drive
Pioneer DVD-106D
All latest drivers installed, the only issue i can see is that the drive is picked up as a SCSI device in device manager.
Cheers J
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
Spec
1gb 2700 Ram
Abit NF7-S Mobo
160gb Sata Drive
Pioneer DVD-106D
Cheers J
