Challenge: Spec me a gaming machine for less than £400
ok so shall I go with the intel option then?
If so, then I cannot begin to thank you more. This has helped me SO much. I've been stuck with this for ages. :D
um i would post another thread with each of mine and arctine's idea builds, and let other people have a look and they will help more, and will give you reasons to why they think you should choose either build :) im stuck on AMD or Intel and can't decide :)
whats with the bad case guys also ,why get amd 2 or dual core when u can get amd 3 athlon 2
also if u want to spend bit more u can change the memory
u cant save few more quid if u chose smaller or worse hard drive. but i would not overall performance what counts.
