Chances of 4 x 16GB dual rank DIMMs working with 5800X3D?
12 Jan 2010
I have a 5800X3D running on a MSI MPG B550 Gaming Edge motherboard with two 16GB sticks of Corsair Vengeance RGB Pro Black running at 3600 CL18. According to CPU-Z the part number is CMW32GX4M2Z3600C18 and they are dual rank DIMMs.
The PC is running perfectly and I have no real need for 64GB RAM and the sensible call here is to not mess around and stick with what I've got.
However!
If I get another identical kit what are the chances of the 5800X3D being able to run 4 DIMMs a) at all and b) at full speed?
5800X3D according to AMD supports the following Memory configurations and speed
System Memory Type = DDR4
Memory Channels = 2
Max Memory Speed
2x1R = DDR4-3200
2x2R = DDR4-3200
4x1R = DDR4-2933
4x2R = DDR4-2667
@RatmanGB
Obviously not quite the same setup but I'm running 4x32GB sticks with a 5950x on an msi b550 mortar matx board and they're happy at 3600mhz... I started with 2 and then added 2 more, I literally just turned on xmp, adjusted infinity fabric to 1800mhz and it all just happily ticked away. They're working fine at 3600mhz even after I tweaked CO/PBO too....
Obviously mileage will vary with the x3D versus my 5950x but it 'should' work imo.
Ram used: Corsair Vengeance LPX - CMK64GX4M2D3600C18
No issues running 4x 16GB sticks of Corsair Dominator Platinum at 3200Mhz (16-18-18-36) with a 5800X3D, originally it ran with a 5950X and had no issues on that chip either.
Model is the CMT32GX4M2C3200C16
Sorry, I've tried to find out via Google but haven't been able to - are those single or dual rank?
Thanks.
Thanks.
They are dual rank.
