Change control
7 Jun 2003
Gloucestershire
I'm after some change control software with the following sort of criteria:
Basic
Customisable fields
preferably an interface that can be operated with just a keyboard
preferably MSSQL compliant
Can anyone recommend me anything of the sort? Everything i find is far too indepth for our needs and has far too much to it. I just need it to be short and simple so i can enter things as i go regarding group policy changes, server settings etc.
we've used gemini from countersoft in a development setting for change control for years. works great, and i think easily applicable to infrastruture change control.
http://www.geminiplatform.com/
Cheers, possibly a bit too in depth for our needs but i instantly noticed the "free for up to 3 users" and pounced on it, will give it a test and see if it does the job. There's only 3 of us that'd be using it so free = ideal :p
Gemini is very good, I've used it before and loved it.
We are now on Fogbugz, the Change Control isn't 100% as adaptable (and annoyed me no end), but it has Version control (Kiln) and lots of really good plugins, and doesn't cost the earth, but that's more for development projects etc..
We currently use RT by Best Practical but I believe we are mirgrating over to a computer associates package shortly
