Change to storage - Advice Needed!!
14 Nov 2012
Chesterfield
Hello,
I’m currently running an OCZ-Vertex 2 60gb as my OS drive and a 1TB Samsung Spinpoint f3 as my secondary drive which contains all my games & programs.
I’ve been considering changing to x2 600gb velociraptor drives running RAID 1 but I’m not sure if there is a better setup I should be looking at.
I’m currently running:
• Gigabyte 990XA-UD3
• AMD FX 6100
• 8GB Corsair Dominator 1600
• MSI Geforce 660 GTX TwinFrozr III
• 1000w Modular PSU
I like the idea of the raptor drives as they are fast & efficient and will not spend the money to have SSD’s instead. My boot time is about 15-20 seconds on my SSD and I would like to keep the speed, hence the raptors. I’ve read that the WD Black/Blue/Green are a good choice, but I don’t know what the speeds are like. Would it be better to run 2x 1.5/2tb drives in RAID 1over 2 raptors at 600gb each?
I would also like some recommendations as to a decent but cheap RAID Controller if you can help.
Many Thanks,
Martin
I'd keep using SSD, What you could do here..
Buy a fast SSD for Windows, use the 60GB as a Games drive (only install games you're playing)
Personally, I'd never bother with velociraptors now, SSD's keep getting cheaper and faster
Well it depends what you want, I'm happy with a 64gb drive (crucial m4), and I have a vertex 2 120gb as my Steam drive for games. Then a WD blue 640gb hard drive for my data.
With a 256GB SSD, you wouldn't need to put your games/programs on another drive, and they're super fast!
Thanks to you both! Not sure which route I'll take at the moment. Love the idea of the 256 SSD, but worried about running out of space. I guess I'll have to only install the programs I'm using. It's mostley IE, Chrome, FireFox, Adobe Lightrooms v3 & Office.
All my other programs are pretty much redundant as they are only installed for the off chance I may need them. Turns out I dont think I do.
Also, funds are limited and I've got a £85 voucher for CEX. I've been looking at the OCZ Vertex 3 120gb or a Corsair F120.
Any comments/experiences?
