Changing fluid please help!
18 Jul 2009
So Ive had feser one red before and that stuff wasn't so good. I then mixed it with the concentrate that you get in a h20-220 ultima kit, green stuff (accidental obviously) but got better temps.
But now after a year I found some cheap red tubing so I figured keep it simple. Whats the bare minimum I need? Is it just distilled water and a silver coil ? Also does it need to be solid silver or will silver plated do ?
Well i personally use distilled water with a silver coil.
The best way to clean it out would be running some distilled water through the loop to turn and get rid of as much dye as possible.
If you had Feser in the loop then you need to strip everything down, especially the blocks. A lot of us had the damn stuff seperate and clog our blocks up. It's terrible stuff.
