Changing from a UW
10 Mar 2003
Hi
I currently have a Samsung C49HG9X which has it's own issues (basically anything above 100Hz or with Freesync on causes it to throw a wobbly - it's a known issue).
So I'm thinking about changing, ideally to 4K. The UW is okay but it's not really a massive thing. I'm not stuck with any particular brand or even a monitor vs TV. The size might be an issue. Whilst I currently have 49" a 4K is going to be higher, which is not a problem, but should I go smaller bearing in mind I'm about 1M back from the screen most of the time?
Does anyone have any reocommendations?
Thanks,
M.
A 16:9 4K screen is not very comparable with a 32:9 1080 super ultrawide execpt for the height which would probably be about equivalent to a 27" 16:9 4K screen (not sure if they make smaller 4K screens anymore). Sitting a meter away I dont think a 27" 16:9 4K screen would be a good option as you will have 4x the pixel density compared to what you are used too. You would probably want 32" or larger for 4K at that distance IMO.
Yeah I was thinking more in the 40" range as it would be a massive change, I have a 1440p 32" as well which I use for work which is okay but the 4K is what I'm really looking for.
M.
