Changing from IDE to SATA
28 Feb 2006
Hi guys, when building my latest setup I decided to economise a bit as I had 6 brand new 160gb Maxtor IDE drives lying around. Lately I've noticed a bit of a grinding noise coming from the primary drive, which is a shocker as its basically 2 months old!
My current setup is as follows :
Intel C2D E6420
Asus P5N-E SLI
2x 160gb IDE HDD
2x IDE DVD/RW
BFG 8800 GTS 320mb
2GB Crucial Ballistix PC6400
Anyway, my question is, will I notice a huge difference if I changed my HDD's to SATA
Totally depends on the drive itself. The interface really won't help you unless it clears a bottleneck. Since PATA IDE is still quite fast you won't notice any speed increase on similar drives.
The biggest difference will be in cabling and future saleability and availability of replacements.
At the moment I can't help but think that the drives are slowing down the rest of the system.
Right they are "Maxtor DiamondMax 17 160 GB - ATA-133"
Drive Transfer Rate: 133 MBps (external)
Seek Time: 8.9 ms (average)
Average Latency: 4.17 ms
Spindle Speed: 7200 rpm
Will a SATA drive offer much of a real world improvement over these? if so, what do you recommend?
Like I said, it depends on the drive, not the interface.
I, like most people on here, would recommend a Western Digital 5000AAKS or Seagate 7200.10 500 drive. Both are very fast, native SATA, 500GB drives that should give you a noticable speed increase over your current Maxtors for about £65
