hello
im thinking of changing my HDD in about 4 weeks and i want to make sure i have all the info before purchasing.
firstly here is my motherboard;
http://www.gigabyte.com.tw/Products...rd&ProductID=1886&ProductName=GA-8S661GXM-775
it says there are 2 sats ports on that and my first question would be will any sats hard drive work on there(sata,sata2)
this is the hard drive im thinking about getting if the answer to my first question would be yes,if no im going to have to start looking again.
my second question is to do with that HDD,i have found another one i presume it is the same one,on an unmentionable website on which i can pay in for it(why itll be 4 weeks) but that does not say sata 2 it says sata300 here is the info given on the other website;
Product Description: Seagate Barracuda 7200.10 - hard drive - 400 GB - SATA-300
Type: Hard drive - internal
Form Factor: 3.5" x 1/3H
Dimensions (WxDxH): 10.2 cm x 14.7 cm x 2.6 cm
Weight: 0.64 kg
Capacity: 400 GB
Interface Type: Serial ATA-300
Connector: 22-position Serial ATA (SATA) plug
Data Transfer Rate: 300 MBps
Spindle Speed: 7200 rpm
Buffer Size: 16 MB
Manufacturer Warranty: 5 years warranty
also if in the future i upgrade to an e6600+motherboard will that HDD still work or should i wait until i upgrade first
Weight: 0.64 kg
Capacity: 400 GB
Buffer Size: 16 MB
