Changing my 4 year old pc setup in something that is descent for 2018, plz help
18 Oct 2018
Hey
Can anyone help me upgrading my 4 year old system to something that will run the new black ops or battlefield with ease on full hd ultra or high settings.
- MSI Z97 - G45 gaming Intel Z97 chipset , ATX, SLI crossfire
- Intel Core I7 -4790K quad core Devils canyon , SKT 1150 , was running at 4.8 GHZ
- Asetek 550LC extreme liquid CPU cooler
- Crucial Ballistix sport 16GB DDR3-1600 CL 9-9-9-24
- two ZOTAC Gforce GTX 770 in sli, 2GB GDDR5
- 750 Watt
Just some main questions, will the motherboard support new DDR4? and support a new graphic card?
Will a 1070 GTI be better then 2 x 770 gtx?
What is compatible and what not...
Don't want to pay too much money, just want to play on a descent pc again :)
What can I keep in my old setup and what has to go?
Much appreciated!!
Kind regards
Ken Neyt
Hello, your motherboard won't support DDR4, but I would probably keep your CPU RAM and motherboard as for the most part they should still do really well for gaming, and I would just upgrade the graphics. a GTX 1070 should perform much better than a pair of 770s in sli, so that would be a good upgrade, though its worth looking at 1070tis and 1080s as well, the prices are a bit all over the place right now, so its possible to grab one for not much more than the 1070 :)
You wont be able to use ddr4 on that mobo.
A 1070 ti will stomp all over a 2x 770 sli setup.
What is your monitor, i assume it is 1080p given you said full hd, but is it a high refresh rate monitor or are you happy with 60hz?
You've picked 2 quite demanding games.:)
So just changing the graphics card would do the trick?
Yes, still 2 four year old 1080 p monitors. .
Yes, still 2 four year old 1080 p monitors. But i'm lookin to change to just one of these.
Upgrading to a 1070ti and keeping what you have should even allow you to drive 144hz on the monitor you've posted.
I would edit out the link to comply with forum rules btw (no competitor linking etc).
As others have said, a 4790K with 16GB RAM and a 1070 (or higher) level GPU upgrade will keep you in 60fps+ territory for at least a couple more years.
