Changing Sigs
28 Oct 2007
Liverpool
I've seen it on here and other forums were somebodies sig changes each time the page is refreshed, I believe this is using HTML within the sig...
Can anyone give me advice on how to do this myself please, it'd be much appreciated :D
Robbi
You use bbcode to link to a server where you run a script that rotates the image. You'll need access to a server, a few guys here sometimes help out with that side of it.
Have a google for sig rotation.
While we're doing sigs... yours are above the maximum file size allowed of 20KB.
So no help just a moan Zefan? I'll sort my sig but as its not hosted by OCuk i dont understand what the problem is:rolleyes:
I don't see why you feel the need to be condescending.
I'm merely pointing out the rules, the fact that I haven't removed your signature already is due to the fact that this thread is about your sig hence I felt it'd be a better idea to tackle the problem through discussion as opposed to just removing it.
The rule is in place due to the fact that images make up the vast majority of the data on a webpage, having a large signature (which we deem to be anything over 20KB and over 400*75 pixels in size) is detrimental to the function of these boards.
Due to this rule this forum is fast and clean - go to pretty much any other forum to see the disjointed devilry that is ridiculously large paragraphs of text and random animated GIFs as signatures. You'll see the contrast.
Fair Point, Condescending statement retracted :)
Think you caught me on a bad day is all ;)
Sig fixed, hope that's more suitable
Right, I thank you for that but i need the coding basically if pos as i want it for images around the 500 x 150 mark so it'll also be a lot more than 20k :P thank you for opening it up inquisitor
