- 3 Mar 2006
- Atcham, Shropshire
I'm hoping someone can help me with this,
I have a CG 125 (a real one) and the battery was cooked, no acid in it at all. I sorted out a battery but when I check the voltage across the terminals when the engine is running its showing 18v rising to over 20v when revving.
I have changed the rectifier/regulator and the voltages are still the same.
I have checked continuity on the stator and thats fine also.
What else can cause the charging system to output such a high voltage?
