I can recommend catalyst2, their cheap deal is good if you don't use too much bandwidth, I use them for several domains - support is v.good as well. Catalyst2
I've been using 1uhosting ( http://www.1uhosting.co.uk ) after discovering them advertising on a random forum a few months ago as a development/test server, and can report no problems whatsoever.
They're still fairly small, but i have found the uptime to be fantastic (one reboot in the last three months or something) and the technical support is first-rate. Defo give them a look.
I have a couple of the 14.09 .net windows accounts - use them for some simple screenscraping duties. I'm afriad I do not know which plans have the SQL databases inclusive. However, a quick check of one of my accounts shows that adding a MySQL database is 25 quid for the year, adding a MS SQL 2000 Db is 49 quid a year. Bit of a stinger really.....
