Cheap CPU for CSGO machine?
31 Jan 2014
Hi, I'd like to build a cheap csgo machine. Have already got a Gigabyte gtx 1080.
Would the i3-12100F bottleneck that gpu? If it would be a mistake, what CPU would you recommend instead?
Many thanks in advance.
CS:GO does quite well on AMD CPUs:
The Ryzen 5 5600X appears to be quite similar to a Core i5 12600K in the game.The Core i3 12100F does do reasonably well for a £110 CPU,but if you shop around the Ryzen 5 5600 non-X can be had for around £130ish. I would make sure you pair the CPU with 3200MHZ or 3600MHZ DDR4. Unless you need PCI-E 4.0,then an A520 based motherboard will be fine for around £70ish but a lower end B550 can be had for around £100 which has PCI-E 4.0 and overclocking support.
Thanks for the advice CAT, will go with what you recommend.
This gives you a rough comparison of performance:
I upgraded CPU a few months back and the only non-dead platform to buy into was AMD, so I got a 7600x. I'm extremely pleased with it and I figure in a couple years I can toss in like a 9850x3d. With a 4080 in doom eternal I get 600 fps 1080, 500 in 1440p, like 350 in 4k if I recall, with RTX off but graphics pinned to max.
With that said, if all I was interested in was a quick and dirty CSGO machine, I'd probly just check kajiji or typical stores for the cheapest vaguely modern CPU/mobo bundle, essentially any CPU from the last 3-4 years will work won't it? Like I'm pretty sure an I7-6700k will pull 300+ fps
Hi, this is what i've come up with, already have gpu and found a set of 3600Mhz Ram in a box :)
Ryzen 5 5600 £150 https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3d2-am.html
Be Quiet! CPU cooler £25 https://www.overclockers.co.uk/be-quiet-pure-rock-slim-2-cpu-cooler-92mm-hs-01s-bq.html
Gigabyte B550 Board £116 https://www.overclockers.co.uk/gigabyte-b550-gaming-x-v2-amd-am4-b550-atx-motherboard-mb-594-gi.html
Seasonic 650W PSU £70 https://www.overclockers.co.uk/seasonic-g12-gc-650-650w-80-gold-power-supply-ca-07m-ss.html
WD Black 1TB SSD £75 https://www.overclockers.co.uk/wd-b...-solid-state-drive-wds100t3x0e-hd-58f-wd.html
Be Quiet! Pure Base 500 Midi Tower case £80 https://www.overclockers.co.uk/be-quiet-pure-base-500-midi-tower-case-black-ca-13p-bq.html
I make that £516. I don't really want to skimp on the psu and would like a quieter cpu cooler but is there anything else anyone would change (motherboard is the cheapest they have in stock atm).
£170 (incl. VAT)
£90 (incl. VAT)
FREE DELIVERY
£100 (incl. VAT)
£90 (incl. VAT)
Looks good, you're right about the PSU, never skimp on that and Seasonic are as good as it gets, £70 for that is quite reasonable.
Same with the motherboard, you can get something a bit cheaper but for the difference in quality its just not worth the £30 savings.
CPU cooler is a little on the light side but a good brand and the CPU you're buying is very efficient, so i don't see a problem there.
SSD, yeah good, not much to say about it.
Nice case...
I'm running a slightly higher end B550 Aorus Elite AX V2 for a 5800X, fantastic motherboard, rock solid and all that... yours is a similar board.
Yeah its all good :)
£170 (incl. VAT)
£90 (incl. VAT)
FREE DELIVERY
£100 (incl. VAT)
£90 (incl. VAT)
£135 (incl. VAT)
£120 (incl. VAT)
Something quieter would be the same but a bit larger.
The one you have linked there has a 92mm fan, the one i have linked below is a 120mm fan, those BeQuiet fans are not bad, they are quiet and the larger cooler will also help dissipate heat, not that the 5600 produces much.
Its about £11 more. or another £5 gets you it in black so it looks like the one in the case photo... Edit: in fact its the one they used.
I'm afraid not, I can't find them at OCUK anymore. For a similar price, maybe the semi-modular Corsair TX650M for £65 (inc del). For another £10 (£80 inc del): Antec Earthwatts Pro EA650G (is semi-modular, Seasonic-built, with a 7 year warranty, if you get the Chinese FSP version then send it back).
If you wanted full-modular, with a 10 year warranty, NZXT C Series, EVGA G6 or Toughpower GF1.
