http://forums.overclockers.co.uk/showthread.php?p=15456519#post15456519
I refer to the adapter on this thread. I can confirm for 100% that the adapter will work with Eyefinity. Currently running 3 x 22inch monitors.
1 x 1950 x 1080
1 x 1650 x 1080
1 x 1650 x 1080.
Set the 1950x1080 monitor to force 1650 x 1080 resolution and hooked that monitor up via the VGA - Displayport adapter. The other 2 monitors are plugged in via the DVI sockets. I understand a few people have a few issues getting 3 to work so i suggest using the adapter on the highest native resolution monitor.
Had a few issues getting the diplays working in the right order, but nothing a few mins fiddling wont fix. Currently playing Batman at 5040 x 1050 on the 3 monitors with about 40-60 fps on a 5850. So im happy.
Hope this helps you guys. Will post a pic of the setup when i get home for lunch if i remember!
1 x 1950 x 1080
1 x 1650 x 1080
1 x 1650 x 1080.
