Additives are the biggest variable in engine oils, cost and performance wise.
A 5w30 using additives that are created and tested to be an OEM spec normally carry approvals.
Additives that have been made to meet the spec, don't carry the cost- some do have the same performance.
The base oils are typically the same used by blenders to hit the viscometrics for each grade.
Some oils can be used across a range whilst others use specific oils to specific grades.
Group I base oil in the likes of 15w40 mineral oil cost 50p per litre, some pao oils cost £5-6 per litre.
Horses for courses.
Horses for courses.
