Cheaper, equivalent air CPU cooler to the Noctua NH-U14S?
Looks like a decent cooler, and good value too, thanks. But, the Hyper Evo 212 (159 mm tall) barely fits in a mid tower PC I just built.
The NH-U14S is 165 mm tall. I have roughly 1cm of clearance, so either of these coolers may just about fit.
Hyper Evo 212
I assume this is too low end then?
but is a tad expensive (~£56)
You could try the FUMA 2, if it comes back into stock. It's currently £49.99 on OCUK, which is a little cheaper than the £56 you mentioned.
Honestly I don't think you're going to get much below £50 without sacrificing at least a little performance, or waiting for a deal.
https://www.overclockers.co.uk/scythe-scfm-2000-fuma-2-dual-fan-cpu-cooler-2x120-mm-hs-04f-sy.html
