CHEAPER GPU SOLUTION!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
With the current crazy pricing levels I have managed to source some 1030's and 730's and even though these have also risen a solid 20% or so in price because they are so cheap to begin with means the price has only increased by £10-20 and as such for some people who are waiting on a GPU to get a rig built or even have a failed GPU and need a low cost replacement, here is a solution:
Palit NVIDIA GeForce GT 1030 2048MB DDR4 PCI-Express Graphics Card @ £74.99 inc VAT
NEC103000646-1082F, Core Clock: 1151MHz, Boost Clock: 1379MHz, Memory: 2048MB, DirectX 12 Support, 2 Years Warranty
Only £74.99 inc VAT.
ORDER NOW
Asus NVIDIA GeForce GT 1030 LP Silent 2048MB GDDR4 PCI-Express Graphics Card @ £89.99 inc VAT
ASUS GT1030-SL-2GD4-BRK, Core Clock: 1189MHz, Boost Clock: 1417MHz, Memory: 2048MB, DirectX 12 Support, 3 Years Warranty
Only £89.99 inc VAT.
ORDER NOW
MSI NVIDIA GeForce GT 1030 Aero ITX OC 2048MB GDDR4 PCI-Express Graphics Card @ £89.99 inc VAT
GT 1030 AERO ITX 2GD4 OC, Core Clock: 1189MHz, Boost Clock: 1430MHz, Memory: 2048MB, DirectX 12 Support, 3 Years Warranty
ORDER NOW
MSI NVIDIA GeForce GT 1030 LP OC 2048MB GDDR4 PCI-Express Graphics Card @ £89.99 inc VAT
GT 1030 2GHD4 LP OC, Core Clock: 1189MHz, Boost Clock: 1430MHz, Memory: 2048MB, DirectX 12 Support, 3 Years Warranty
ORDER NOW
Palit GeForce GT 730 SILENT 2048MB GDDR3 PCI-Express Graphics Card @ £59.99 inc VAT
Core: 902MHz, Memory: 2048MB 1600MHz GDDR3, Stream Processors: 384, PhysX/CUDA Enabled, DirectX 11.2, OpenGL 4.4, 2 Years Warranty.
Only £59.99 inc VAT.
ORDER NOW
I do not believe they have the video encoder built in (so the CPU has to do the video encoding and can struggle if it is weak). I had to upgrade the CPU just to watch Youtube at 4k.
Also the DDR4 variants are immensely slower than the DDR5 versions.
If you're just after a low profile graphics card then the price isn't that bad, just make sure you note the above.
Note that the GT 730 is no longer recieving driver updates.
It's still receiving security updates until 2024. They've already put out one new bugfix driver for Kepler cards since the end of mainstream support. Realistically, you're not going to lose out on anything not having Game Ready drivers for such a card, since they won't run any modern titles anyway.
Apparently it does, but only up to 1080p. Doesn't support HEVC either so won't make a good HTPC card.
