Cheapest system?
25 Aug 2005
Derbyshire
I'm thinking of building a car PC but don't have much cash.
I'll need eveything except monitor and case (power supply also due to DC-DC needs)
So can anyone spec up a really cheap AMD solution please. Minimum of 512mb ram.
I guess 250-300 quid maybe??
Cheers
Well, from the reading I've been doing, and from obvious common sense, a normal PSU won't do it as it will be run from the car battery, via a DC-DC converter. That's if I've read it correctly (PS car is a mk4 golf and I've seen a nice boot install on some forum somewhere)
Just wanting to see how much money I might be needing to save up, so wanted to see how cheap a pc someone can spec.
most of those psu's of a 12vdc feed are only 75watt-120watt,
which i was i saying you should find your psu/convertor first and tell people its rating so they can help you spec it,
