I'm currently using Tiger but I'm looking to try out Plex which is only compatible with Leopard. What's the cheapest route for me to upgrade from Tiger, and how much would I be likely to have to spend? Are there cheaper "upgrade" versions rather than "new install" versions? Are there any other options available to me? As you may have realised, I'm looking to do this as cheaply as possible.
Thanks.
Thanks.
