Check/advice
25 Sep 2009
First ever package, can you tell me if components would work together it would be used just to surf listen to music play a few games nothing fancy anything would be a great improvement on my laptop..
Any advice on paying that little bit more for something that would make a big improvement please help.
thanks
i would suggest to start with go for a 22inch lcd (£3 more), and also a better graphics card, (£7 more) maybe a ati 4850 can be had for little more than the one you have there
and im sure someone will build you up an i5 rig, do you have a budget in mind?
The ati 4850's are ddr3's will they be compatible? Well Id prefer not to have the new stuff, I remember last year reading wait a year you'll get all the topspec cheaper if you wait.
"save 40% price getting 95% of the performance by waiting 1 year rather than getting the top spec of now paying the full whack"...
Im not saying my list is top spec of last year because I don't know but I for sure would like to see a bundle that is all about value..
you wont get much value from a 9600gt compared to a 4850, its not new tech either, where have you been :D:D
I was referring to the suggestion of an I5 rig..
Yes lol Im very new to this I just see new tech as being ripped off price wise..
Im after value and basically havent got a clue so anyhelp appriciated, this certainly beats comet or currys etc
personaly if me id be doing the 4850, 22 inch lcd for definate and maybe a tweak here and there on the rest, do you have a budget ? would help people a lot if you did, also have you got an OS allready as its not on your list.
Budget can go to 1k if the price is worth the performance, I do have vista ultimate but its ony 32bit.. I have changed my basket with the suggestions.. 22inch lcd, case and 4850
thanks
Too add a little umph maybe this cpu with this video card but you'd need a better power supply. Something like this or a bit cheaper this adds an extra around £150 but for the gaming you do it will definetly be beneficial aswell as general computer tasks.
