Check CPU
Man of Honour
15 Mar 2004
Liverpool
I know for hard drives some manufacturers' websites allow you to enter details in and they'll tell you information about the product you have.
Can this be done anywhere on AMD's website about an AMD CPU I have?
Cheers :)
It's something else I've kind of pondered for a while. I bought a CPU a while back from that auction site as it was dirty cheap and because I couldn't get it to cool below 40 celcius I started to be suspicious and think it mayhave been a lower CPU which had been overclocked.
It came without much in the way of a seal or original packaging...should stick to buying stuff here :(
What sort of CPU was it? If it's a socketed one then you'd probably see any pin or pencil mods at first inspection. If it was an older CPU in a slot package, then you'd have to open it up and look for mods.
For an older cpu, like say a PIII or Socket A (with many board combos) it might only display the running MHz speed and in Athlon XP cases, the calculated PR rating not the actual cpu name.
AMD AM2 6000+ Oem, that was pretty much what it was advertised as..
I have the numbers here - but don't know what to do with them...
There are no pencil marks anywhere..
And when my computer did post (see my thread in GH :(), it never ever displayed the CPU name - only it's clock speed and "Unidentified CPU"
Likely not tampered with mate, extremly hard to do if not impossible, the model no. is programmed to the cpu and i don't know of anyone who can mod the multipliers etc.. not to mention problems with removing IHS etc.. :)
edit - Ahh unidentified, cpuz should still tell you what it is, you need to update your BIOS to identify it properly.
