Okay, time for an overhaul. My old comp (XP2600+, 512MB DDR, geforce 6800) has been great for the last couple years with the occasional gfx card upgrade, but is now starting to struggle a bit with newer games. I'm taking the opportunity to build a new system from scratch.
The budget is around £1.2k, but that's not set in stone - I'll happily got to £1500 or so if it's worth it.
The goal is a new system (minus the keyboard, mouse, monitors, and optical drive, which I will keep from the old system) which will be a seriously powerful gaming rig which is also very quiet.
Here are the bits I've come up with so far:
Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO) 1
£194.95 £194.95
Asus A8N-SLi Premium nForce4 SLi (Socket 939) PCI-Express Motherboard (MB-111-AS) 1
£104.95 £104.95
AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail (ADA4400CDBOX) (CP-127-AM) 1
£284.95 £284.95
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC) 1
£139.95 £139.95
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA) 2
£54.95 £109.90
Enermax Noisetaker 600W EG701AX-VE(W) SFMA ATX2.0 SLI Compliant PSU (CA-021-EN) 1
£78.95 £78.95
Creative Sound Blaster Audigy 4 7.1 EAX Sound Card - OEM (SC-037-CL) 1
£29.95 £29.95
Altec Lansing 5100 Enhanced 5.1 Speaker System (SP-000-AL) 1
£49.95 £49.95
AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR) 1
£14.50 £14.50
Subtotal £1,008.05
VAT £176.41
Total £1,184.46
(The case I'm buying elsewhere for around £60, which is not included in the spec)
Any thoughts? Any important bits I've missed?
I'm not sure if it makes any difference whether I go for the A8N Sli premium or deluxe.
I'm also tempted to replace 1x spinpoint with a 74GB raptor in a silentmaxx enclosure, but I'm not sure exactly how quiet this will be and I'm wondering if it might get a bit hot?
I'll probably make my decision and place the final order at the weekend.
£194.95 £194.95
£104.95 £104.95
£284.95 £284.95
£139.95 £139.95
£54.95 £109.90
£78.95 £78.95
£29.95 £29.95
£49.95 £49.95
£14.50 £14.50
Subtotal £1,008.05
VAT £176.41
Total £1,184.46
