News about next release
At this moment I'm finishing adding new method of overclocking for R5xx boards. This method will be called "Driver Level".
What will do this method:
1. Overclocking will be done by Catalyst itself like Overdrive
2. Voltage will be applied by driver for GPU and by ATT for memory
3. ATT will emulate Overdrive job, but will allow to set clocks when you want it instead of when you run full screen 3D application.
4. This should work even if you didn't disable ATI HotKey poller! And clocks will not resets by that service in 3D games
5. With this method clocks will not resets when you play any video files (checked on my 1800XT, no more resets)
6. More stable overclocking. Catalyst know HOW to do overclock job better that any other utils
________
I hope this method will work without problems, but there are some disadvantages:
1. It seems that this method can be used only on video boards with Overdrive support (I will check it with non Overdrive board 1600Pro)
2. The step in MHz will be higher than in Low Level ( about 6MHz)
