Check spec before order
28 Sep 2003
London
is this all compatible ?
anything you would change ?
not sure on the PSU ?
is the cooler a good choice ?
is retail cpu better than oem for £10 for any reason ?
thank you
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £269.99
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £37.99
Xigmatek Asgard Pro Gaming Case - Black £32.99
OCZ CoreXtreme 500w '80 Plus' Power Supply £32.99
XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £59.99
Thermalright True Spirit 120 REV A CPU Cooler (Socket LGA775/1155/1156/AM2/AM3/FM1) £24.98
Retail is worth extra for the added cover.
That CPU cooler is good. Won't get super high overclocks though.
Are you running a gpu with it?
Retail is better as you get the heatsink with it and the extra warrenty. as you are getting an aftermarket cooler you'll bust benefit from the extra warrenty (worth the £10!)
You could probably get cheaper RAM I'd of thought (I cant check right now but will do shortly)
happy for recommendations for a better cooler
i have a GPU that i will use for now (radeon 6800) until i get something better
also happy for better RAM recommends
thank you
