Check Spec....
Caporegime
18 Oct 2002
London
Intel Core 2 DUO E6300 £126.89
GeIL 2GB (2x1GB) PC6400 800MHz £146.82
Gigabyte GA_965P_DS3 £108.09
Connect3D ATI Radeon X1800 XT 256MB £152.74
Arctic Cooling Freezer 7 Pro CPU Cooler £17.61
Total £552.15inc VAT
Planning on getting this setup but in stages as i cant afford it all at once. Gonna overclock - hopefully 2.8Gh-3Ghz. Just a few questions:
Is all compatible (memory and mobo) - heard some DDR2 memory doesnt work with certain Core 2 Duo motherboards.
What is the cooler like on the X1800XT? Heard the ICEQ3 is meant to be a good cooler, can it be brought by its self and slapped on?
You might wanna swap the arctic for a ninja.
The iceq3 is a GREAT cooler, but only comes in prepackaged cards, I would reccomend the VF900 GPU cooler.
Not to keen on Ninja as i wanted one that could be easily installed. Seems that Artic is easier to install than Ninj (and cheaper).
