- 7 Oct 2004
The last time i built a system was nearly 6 years ago now, so to say im out of the loop is an understatement, i have been reading these forums for months trying to see what works well, what people are saying etc etc, there are still some parts i need but hopefully the knowledge from the community here can fill in the blanks.
So far
EVGA GeForce GTX 680 Classified 4096MB GDDR5 PCI-Express Graphics Card
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard
Intel 520 Series 180GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail
Corsair Vengeance Low Profile 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit
I went with the low profile RAM as im not sure there will be clearance with a cooler on there,
I have seen where they say dont use the Intel cooler and get another one, but which one is good for this board etc,
I was planning on i7 but after reading the forums ( this comp is primary gaming ) the i5 3570k was recommended, i have no used a Gigabyte board in at least 10 years, ( last time wasnt so good ) but the 1 i picked is recommended.
So, what i need,
CPU cooler
/doh there are 1000's to pick from.
Case,
I was looking at the Lian Li PC-V2120X but as its out of stock i may go elsewhere or pick another, the comp will be air cooled, does anyone use this case etc, what is a good case, i dont want a window in the case.
PSU,
There are like 100's to pick from which 1, i dont want something that will blow up when the comp needs the power for gaming.
Monitor,
I was looking at the U2711, ( which is why i picked the GFX card that i did ) i may go with the U2410 for now and upgrade later, the 120Hz 3d are no good for me, as i have eye sight issues and 3D does not work for me at all.
Sound,
Is the onboard sound any good these days, last time i used on board sound there was like a low pitched noise coming threw the headset all the time, so i switched to Audigy 2, but its kinda out dated now.
This will be running Win 7 64bit
Did i miss anything out,
Input would be great,
Thanks.
PS: this system will not be overclocked, i have no need for overclocking these days.
So far
So, what i need,
CPU cooler
Case,
PSU,
Monitor,
Sound,
Thanks.
