Hi there,
I've got a laptop here that was running extremely slow, so decided to format. This only made things worse, it takes 2 hours to get 1% formatted on the normal XP format mode ( not Quick mode ). It's a 40GB drive, internal laptop drive.
I've tested the RAM, all seams fine. So took the HDD out and put it into another one of my laptops and ran into all the same problems with things taking 1000x times as long as they should.
Is there a way to test a hard drive for faults? Preferably using a boot able CD?
Thanks.
Thanks.
