Chill / Kodi machine.
15 Nov 2009
Northumberland
Spec Check help/Advice
Do not wanna spend a fortune on hardware i don't need its not going to be my gaming machine.
Right now it will be mainly streaming 1080p and some movies i have on my server.
In a few months playing back some 4k media also hence the skylake?
Thanks
Hey Begbie
The gear i have is loud and big all from gaming rigs, the machine i would like to build ideally would be small and quiet, So i would have to buy some parts regardless of using some older gear
Thanks
Spec would be fine for the purpose.
FYI...I have a HTPC for sale in MM...check if it takes your fancy.
I use a fire stick for Kodi and streaming from my Synology running Plex. Works absolutely fine at 1080p! Why bother with a new build when it's not really needed?
Thanks
Use a Raspberry Pi for Kodi, much better.
