They all have a different base clock, do you even know what IPC is?
yes instruction pre clock but a lot of people say X is as fast as Z when they do a single task
Then the only was to test that is to have them all at the same clocks.
Just to be clear i went 6700k @ 4.1 to a 1800x because i was the newer / bigger is better guy like a lot of people. so basically i'd have a big ass down grade when everyone started raving about Ryzen been amazing
then i went 1800x to 2600x to 3600x that's a lot of cash to end up back where i started
but if you only game, you do CPU vs CPU
AMD only passed skylake with there 3XXX chips
i5 4690K @ 4.6Ghz: 33 FPS, 47% GPU load.
Ryzen 1600 @ 3.85Ghz: 85 FPS
4t vs 12t....
take the same screen shot with a 4790k???? or ever a x79 CPU? no? why?
IPC... 4cores vs 6/12cores
ill fire you back to your first post do you even know what ~IPC~ is???
4t vs 12t....
make the same point with a 1600x vs a 5820kI'm not making an IPC point with that....
That.
so your point is in a heavy threaded game a 4t cpu will lose to a 12t cpu....That.
4t vs 12t....
CPU vs CPU comparisons
You're the one who moved the discussion away from IPC and suggested CPU vs CPU comparisons in gaming, why are you bringing up IPC again?
What?well that outstanding, so we can all but 1800x's @humbug said that the bestest
yes but not 4c vs 16c... and also 2014 vs 2017
can we play fair?
1600x vs 7700k??
again i did say sorry i thought zen3 was 3XXX chips, well done for reading everything before you jumped inAgain, you're the one who brought up the Zen 3 vs 6th gen Intel comparison.
in games the amd 3XXX chips matched the intel 6XXX, say 3600 vs 6700k
i made an error i thought zen3 was 3000 chips
Nonsense. 6th Gen Intel came in 2015, Zen 2 (AMD 3xxx) came in 2019. However you want to spin this, you're the one who started the unfair comparisons which you're now criticising.
he dropped in a 1600x
yes 12threads vs 4, a 6700k would have killed it(it did kill it for a long time lolz...)So he made it more fair.
