It is close. Just size is bigger. Not stock android but apparently closer to it.Pocophone F1 is pretty much that, not sure about the size against a XZ2 compact, but 4000mAh into a small phone is kinda asking them to change physics.
Out of intrest how long do they take to process an order? mines been 3 days
Does the speaker have an amplifier built in? The fact the phone thinks headphones are plugged in is normal, you're using the headphone socket. It can't tell that you've plugged something else in.I have a weird issue, at work I have a speaker with an aux connection but plugging it into my Redmi note 5, it thinks headphones are plugged in and plays no sound, is there anyway to resolve this?
No, I've got a Sony portable speaker at work that does Bluetooth and aux but the BT function doesn't work so I've always connected my phone through the aux port and played my songs through the Sony speaker from my phone.I don't get you? You want to plug into the headphone jack, but still get sound through the phone speaker?
Never had an issue before, I used to use an aux cable from my Sony speaker all the time using my iPhone X, it never once thought I had headphones plugged into the phone.Does the speaker have an amplifier built in? The fact the phone thinks headphones are plugged in is normal, you're using the headphone socket. It can't tell that you've plugged something else in.
Have you never used aux before?But that's what confused me. Something is in your headphone jack, it should just play the music through it.
Does it work with actual headphones plugged in?
They just work, if I take a 3.5mm auxiliary cable and plug one end into my phone and the other end into a portable speaker, it should play music from my phone through the speaker it's connected to.So, other phones know what is on the end of the headphone jack cable? I'm honestly asking as I don't know how they would do this?
eGlobal took 8 days from order to receiving the Poco for me.
is it normal to have order processing after 4 days of making the order?
Yes, tracking doesn't update until it hits the UK.is it normal to have order processing after 4 days of making the order?
There is a strong typhoon in Asia at the moment so orders will likely to be delayed.is it normal to have order processing after 4 days of making the order?
