Chk Disk issue on boot SSD
5 Apr 2010
On Your Screen
Installed my new Crucial M4 yesterday, it's running on the latest firmware 0009, installed windows 7, but when I boot the machine up it always tries to do a chk disk, which is rather annoying, I haven't done any settings for the SSD to get it optimised, but how do I fix this issue, don't really want any work around's like disabling chkdisk in registry, but a proper fix for whatever the problem is.
Cheers
^ yep disconnected my two other drives, might give windows another reinstall when i'm bothered and see if it fixes the issue.
Have you tried removing the 'dirty bit' that chkdsk will create?
This is a guide I've found on another forum:
"Start> Run> bring up a command prompt by typing in “CMD” (make sure it is running elevated.. ie as administrator) and type:-
Code:
fsutil dirty query c:. Press enter. This queries the drive, and more than likely it will tell you that it is dirty. Next, type:-
Code:
CHKNTFS /X c:. Press enter. The X tells Windows to NOT check that particular drive (c) on the next reboot. At this time, manually reboot your computer, it should not do a Chkdsk and take you directly to Windows.
Once Windows has fully loaded, bring up another CMD prompt (elevated) and now you want to do a Chkdsk manually by typing
Code:
Chkdsk /r c:. This should take you through 5 stages of the scan and will unset that dirty bit. "
