chkdsk report... is my HD on its way out?
1 Dec 2002
Hi all, last night my world of warcraft crashed twice with corrupt files or something. So i ran the repair tool and it said to reinstall. Reinstall failed 4-5 times. I deleted about 10 gigs of stuff and then tried again. Kept failing. So i did a chkdsk /f /r and the results are as follows: Stage 4 took ages probably becase my HD is fairly full. I am a lil worried at the bold section.. what do those mean?
Event Type: Information
Event Source: Winlogon
Event Category: None
Event ID: 1001
Date: 10/04/2007
Time: 01:33:51
User: N/A
Computer: **************
Description:
Checking file system on H:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
Cleaning up minor inconsistencies on the drive.
Cleaning up 13985 unused index entries from index $SII of file 0x9.
Cleaning up 13985 unused index entries from index $SDH of file 0x9.
Cleaning up 13985 unused security descriptors.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
245103673 KB total disk space.
212989388 KB in 116317 files.
46828 KB in 9335 indexes.
0 KB in bad sectors.
848649 KB in use by the system.
65536 KB occupied by the log file.
31218808 KB available on disk.
4096 bytes in each allocation unit.
61275918 total allocation units on disk.
7804702 allocation units available on disk.
Thanks in advance for any help or advice :)
[edit] I have since reinstalled WoW from the 3gig download and it seems to be working fine.
Im no expert but it looks like windows chkdsk has done its job correctly
says no bad sectors so i wouldnt worry
2p :)
sweet, i am relieved. For once it is 'working as intended' (for you wow players like me hehe). I am saving for a big upgrade in the near future and did not want to be forced into an emergency buy.
