Hi Guys, These are the two im looking at:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-318-CM
And
http://www.overclockers.co.uk/showproduct.php?prodid=CA-049-AE
Now: the Xpredator allows (and includes) a larger 200mm intake fan which is nice, But id really like to fit two side case LED fans, however with 186mm clearance for CPU coolers (mine is 159mm) that leaves only 2mm gap between my cooler and a side intake fan, is that enough?
the CMStorm Scout has a less appealing window, but the side fan mountings wont interfere with the CPU cooler as you can see, however there is not a single mount on that case for more than a 120mm fan, noise time?
the CMstorm looks a bit less tacky also, but im worried after i got it, id fancy a bit of bright+tacky! it's also £5~ more than the Xpred
Both are aesthetically pleasing, and have room for the hardware i want on the inside, so i have a feeling whichever i choose i'll always be thinking 'what if..'
so what are your opinions?
And
