Any good tried and tested recipes? I wouldn't mind making a Christmas cake. No one I know actually likes them, but what the hell!
I put my brussel sprouts onto boil last week, do I have enough time?
I think this is the recipe I used (pic above). One thing I SERIOUSLY questioned, was the cooking time.... I think closer to two hours (or maybe less) was fine.... so beware!
Ingredients:
2 x 500g pack luxury dried fruit
150ml brandy
100g pecan nuts, roughly chopped
50g whole blanched almonds, roughly chopped
grated zest & juice of 1 orange
grated zest & juice of 1 lemon
275g butter, softened
275g unrefined dark brown soft sugar
5 medium size eggs, beaten
2 tablespoons black treacle
325g plain flour
1 tablespoon ground mixed spice
50g ground almonds
Method:
1. Place the dried fruit in a large bowl & stir through the brandy, cover & leave to stand overnight.
2. Preheat the oven to 150°C, 300°C, gas mark 2. Grease & line a 20.5cm round cake tin. Tie a double thickness of brown paper around the outside of the cake tin.
3. Stir the nuts into the dried fruit mixture with the zest & juice of the orange & lemon. Cream the butter & sugar together. Gradually add the beaten eggs & the treacle. Stir in the fruit & nuts. Sieve the flour & spices together & fold into the mixture with the ground almonds.
4. Spoon the mixture into the prepared tin & smooth the surface with the back of a wet metal spoon, making a slight indentation in the centre (this gives the cake a level top when it cooks).
5. Place a circle of greaseproof paper, slightly larger than the tin, with a 5cm hole in the centre, over the top of the cake; this prevents the surface from over cooking.
6. Place the cake on the centre shelf in the preheated oven & bake for approximately 4½ - 5 hours. Check after 4½ hours with a metal skewer, if the inserted skewer comes out clean, then the cake is cooked. Leave the cake in the tin until it is cold, and then peel off the greaseproof paper.
7. Wrap in fresh greaseproof paper and tin foil & store. Follow Cook's Tip for how to mature the cake.
8. Cook's Tip: Once the cake is cold, turn it upside down on the wire rack & make holes in the cake using a skewer. Drizzle a few tablespoons of brandy or alcohol of your choice, over the base of the cake, allowing it to soak into the holes. Wrap the cake in greaseproof paper & then in foil. Each month feed the cake with a tablespoon of alcohol. Do not use too much alcohol otherwise the cake will become soggy.
